stevelalk
#1 Posted : Friday, December 18, 2009 7:04:09 AM(UTC)
stevelalk
I have a Whirlpool Stove RF386PXG0 and the 1200 watt front right burner is not working . One day my daughter was boiling water and forgot the burner was on. From then the burner has not worked. I have check with my Ohm meter the other burners at the place where they the wires go into the element. When I turn on the burners that work the all have power at the element however the burner that is not working there is no power at the element when I turn the switch on. Would it be the Limiter that is bad, or could it be the element? If it is the limiter, can a person purchase a new limiter and insert it into the element? How hard a job is it? It looks simple! Does the limiter slide out and slide back in? If you could help me with this I will be buying the parts from you.
Thanks, Steve
#2 Posted : Friday, December 18, 2009 3:43:20 PM(UTC)
Replacement parts for RF386PXG0 models | AppliancePartsPros.com
Here is a manual on how to
https://secured.whirlpoo...5ef62c/$FILE/8178042.pdf
I do not work for AppliancePartsPros and could not find an exact match to your unit, may be best to give them a call to ensure you receive the correct part.
stevelalk
#3 Posted : Saturday, December 19, 2009 8:18:39 AM(UTC)
stevelalk
Thanks for the help, appreciate the site
samsung electric burner not working (Oven Repair (including Ranges and Cooktops))
by ag0240 8/21/2022 1:58:31 PM(UTC)
Frigidaire range burner not working (Oven Repair (including Ranges and Cooktops))
by Hatt65 12/6/2020 11:35:18 AM(UTC)
Thermador x-lo burner not working (Oven Repair (including Ranges and Cooktops))
by burright 12/30/2014 4:45:01 PM(UTC)
Inner ring of 3 ring burner not working. (Oven Repair (including Ranges and Cooktops))
by William Johnson 3/17/2014 3:58:56 PM(UTC)
Kenmore gas range bottom burner not working (Oven Repair (including Ranges and Cooktops))
by scott mcgourley 10/29/2013 9:09:28 AM(UTC)
Left Front burner not working (Oven Repair (including Ranges and Cooktops))
by tyee3 2/18/2013 2:19:47 PM(UTC)
GE Spectra Profile - Large Burner not working properly - even after replacement (Oven Repair (including Ranges and Cooktops))
by friarpat 12/14/2012 9:15:17 PM(UTC)
Burner ON light stays lit but burner not working (Oven Repair (including Ranges and Cooktops))
by mkc5869 4/19/2012 6:03:56 AM(UTC)
top right burner not working (Oven Repair (including Ranges and Cooktops))
by erakowsky 4/9/2012 5:28:22 AM(UTC)
Range top burner not working (Oven Repair (including Ranges and Cooktops))
by Rolands 3/29/2012 7:25:32 PM(UTC)
Kitchenaid RR burner not working (Oven Repair (including Ranges and Cooktops))
by curtball 3/16/2012 8:32:38 AM(UTC)
Kenmore elite burner not working (Oven Repair (including Ranges and Cooktops))
by Keaka 2/27/2012 2:46:20 PM(UTC)
Jenn Air Burner Not Working (Oven Repair (including Ranges and Cooktops))
by whiterr 11/18/2011 5:24:59 AM(UTC)
glass top burner not working on whirlpool range (Oven Repair (including Ranges and Cooktops))
by heidishandy 10/22/2011 7:54:41 AM(UTC)
Burner not working (Oven Repair (including Ranges and Cooktops))
by Tiny 9/22/2011 8:27:31 AM(UTC)
