kcfamilyconnections
#1 Posted : Wednesday, December 16, 2009 5:16:19 PM(UTC)
kcfamilyconnections
My Maytag dishwasher won't stop running. It acts like it is going to stop, then continues rinsing or washing. I am not sure. What is this and how can I fix it? Thanks! I have a kid with a pretty serious medical issue so any help would be appreciated. Thanks
#2 Posted : Thursday, December 17, 2009 12:28:53 AM(UTC)
Replacement parts for MDB5601 models | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/d...atic%20-%20W10179503.pdf
Could be the unit is waiting for the water to heat to the required temperature.
Try a Rinse Only cycle if that completes then the above is likely.
Check the heater itself should be about 15 ohms, it's thermostat should be 0 ohms and the thermistor should be around 10,000 ohms.
wp2008
#3 Posted : Friday, December 18, 2009 6:25:14 AM(UTC)
wp2008
You should call Maytag at 1-800-344-1274 to check for recall or anything.
