tomking
#1 Posted : Wednesday, December 16, 2009 9:29:47 AM(UTC)
tomking
Fridge and freezer work great only with the upper grille assembly removed. Coils are clean and defrost timer has been replaced. Where do I go from here?
#2 Posted : Thursday, December 17, 2009 5:28:56 AM(UTC)
Sorry but do not understand
If freezer is working great, why would you replace the defrost timer?
Cannot see why removing the grill would make a difference unless the condenser fan is not working.
Also if the freezer is working great it should freeze the water.
Perhaps measure the freezer temperature, it shoul be around 0 degrees F.
tomking
#3 Posted : Thursday, December 17, 2009 8:33:15 AM(UTC)
tomking
Okay, just trying the quick easy fix with the defrost timer. So upon futher inspection the defrost heater and terminator work fine. So now what?
#4 Posted : Thursday, December 17, 2009 5:34:57 PM(UTC)
Check the freezer temperature.
Check for power at the condenser fan
