3 Pages<123>
washer
#11 Posted : Thursday, February 28, 2008 4:03:17 PM(UTC)
washer
This one woke me up to GE quality. A relatively new, builder installed GE dishwasher started leaking from the right side. Even though it was keeping my tile grout clean I opted for a new dishwasher (not GE). When I removed the machine the cause of the leak became clear. The body of the machine was bowed outward making it impossible for the door gasket to seal properly. Isn't that a beaut?
Don Evans
#12 Posted : Friday, February 29, 2008 8:16:36 AM(UTC)
Don Evans
Good Morning Gene,
The tip that you gave me was right on the money. I didn't have to change the latch, my problem was that we were not closing the detergent door when we started the wash cycle.
Don Evans
Don Evans
#13 Posted : Saturday, March 8, 2008 10:41:26 AM(UTC)
Don Evans
Hi Gene,
I'm sorry for the confusion. I took the inner side of the door off and the soap dispenser appears to be working properly. The dishwasher is actually leaking on the left side not the right. I tighten all of the screws pretty tight when replacing the door, however more water seems to be comming out now then before.
Don Evans
#14 Posted : Sunday, March 9, 2008 2:15:55 PM(UTC)
Hi Don,
Check the vent screen (#12 on the inner door break down diagram) for any blockage.
Inspect the door gasket.
#15 Posted : Monday, March 10, 2008 1:45:02 AM(UTC)
Open the door while the dishwasher is running. See if the wash arm is spraying sideways from a split spray arm. Also, check to see if the dishwasher is over filled.
santongiorgi
#16 Posted : Wednesday, March 12, 2008 7:21:22 AM(UTC)
santongiorgi
I have a Kenmore dishwasher, mod. 363.1517000, that leaks when it is rinsing. I believe it is leaking from the bottom. It's around 6 years old. Any advice?
#17 Posted : Wednesday, March 12, 2008 1:54:16 PM(UTC)
Hi santongiorgi,
Remove the bottom panel and check where exactly it's leaking from.
Post your findings.
MarkSpencer1
#18 Posted : Wednesday, March 12, 2008 2:55:26 PM(UTC)
MarkSpencer1
Whirlpool du810dwgui 1999 model leaking bottom right corner thru the door. I replaced door seal already, disassembled door and cleaned hard water deposits, do not see anything "broke".
When I stuff a little cloth inside door at bottom/end of door seal, water leak stopped. only work around though. Leak is mainly when start washer, water seems to squirt.
Mark
#19 Posted : Wednesday, March 12, 2008 3:02:47 PM(UTC)
Hi Mark,
Remove the inner door panel and check for a leak through the latch (#3 on the inner door break down diagram).
Here are the break down diagrams for the Whirlpool dishwasher Model DU810DWGU1
MarkSpencer1
#20 Posted : Friday, March 21, 2008 11:31:56 AM(UTC)
MarkSpencer1
I checked for leak at latch, no leak there.
As soon as the water starts going into the dishwasher, the water squirts out the bottom right corner.
After I checked the latch for leak and reassembled the door, I turned the dishwasher on, the inlet water shoots from the left side across the dishwasher into the corner where the water leaks.
I immediately opend the door, the inside of the door was still dry up by the latch.
I cleaned all the hardwater deposits off the door prior to this test.
The inlet water opening is clean with no mineral deposits.
HELP! -------Thank YOU!
Guest (4)
LG LDF7774ST leaking dishwasher (Dishwasher Repair)
by corvets 4/25/2020 5:12:21 AM(UTC)
Leaking Dishwasher (Dishwasher Repair)
by theflanigans 9/2/2015 6:42:39 AM(UTC)
Non-Handy Woman + Leaking Dishwasher = DISASTER (Dishwasher Repair)
by cbrennan 10/12/2013 5:24:02 PM(UTC)
Leaking Dishwasher (diverter motor) (Dishwasher Repair)
by rmsmith 4/19/2012 7:18:44 AM(UTC)
by mljoecks 10/15/2011 9:14:30 AM(UTC)
by clints 8/27/2010 11:44:16 AM(UTC)
by pdl 3/10/2010 5:06:33 PM(UTC)
by macnlrc 11/9/2009 4:49:54 PM(UTC)
Leaking dishwasher (Dishwasher Repair)
by Brucefamily 9/3/2009 2:22:34 PM(UTC)
by tammyneedshelp 3/1/2009 1:28:36 PM(UTC)
by EMHBARMAN 2/29/2008 2:31:42 PM(UTC)
by warrenjr 12/3/2007 4:34:05 AM(UTC)
by verne k 11/6/2007 6:25:42 AM(UTC)
Leaking dishwasher door (Dishwasher Repair)
by flowboard 9/21/2007 11:14:46 AM(UTC)
3 Pages<123>
