privilege42
#1 Posted : Tuesday, December 15, 2009 4:11:54 PM(UTC)
privilege42
I recently purchased a water inlet valve from you and everything was working fine until today. The washer fills, but will not go into the wash cycle. If I manually advance the dial to rinse it will start to spin and drain. I tried to turn the dial to wash mode in other cycles, but no luck.
sidfink43
#2 Posted : Thursday, December 17, 2009 4:46:46 PM(UTC)
sidfink43
This is an older model, probably in the age of 15 to 20 years old. It was a very good machine for its day, but newer ones are bigger and better.
I would check the connections and the wiring. Also here is a site which will give you some trouble shooting ideas for your machine.
http://www.applianceaid.com/ge-os-wash.html
I would not recommend sinking a lot money into parts for it, and instead if you cannot get it going I suggest you purchas a good used or new top loading no frills washer.
privilege42
#3 Posted : Thursday, December 17, 2009 5:53:38 PM(UTC)
privilege42
Thank you for taking the time to answer me. I think you may be right about connections. If I smack the back panel behind the dial it works fine. I'm going to check all the connections and go from there. Again, thank you!
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
GE washer GTW750CPL0DG (Washer Repair)
by Guest 1/28/2024 11:49:12 AM(UTC)
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 8/29/2023 7:01:15 PM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 3/27/2023 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
