tim
Tim Lim
#1 Posted : Saturday, December 12, 2009 12:32:45 PM(UTC)
Tim Lim
error f3 and f4, replaced temperature sensor but still have the same error. What else is the problem?
#2 Posted : Sunday, December 13, 2009 3:51:51 AM(UTC)
Here are the parts
Replacement parts for artsc8651ss models | AppliancePartsPros.com
Here is the tech sheet in case you do not have it.
http://www.servicematters.com/m...brary/docs/T232_34R1.pdf
Unfortunately it sounds like the control board is gone, especially as the errors are opposites one a short the other an open.
Tim Lim
#3 Posted : Tuesday, December 15, 2009 2:52:47 PM(UTC)
Tim Lim
Is the control board, the ERC? If it is, I've just replace it a year ago. Can it go out that quickly? It's expensive.
#4 Posted : Tuesday, December 15, 2009 3:06:44 PM(UTC)
Yes
Yes if you are unlucky.
You have replaced the sensor. When you did this you probably had the power off to the unit for some time so if the board was going to reset it would have.
So it is my best guess.
It's expensive.
Yes it is at $207.44
Tim Lim
#5 Posted : Tuesday, December 15, 2009 3:26:00 PM(UTC)
Tim Lim
But it was erroring F3, F4 before I've replaced the heating sensor.
#6 Posted : Wednesday, December 16, 2009 1:39:47 AM(UTC)
"error f3 and f4, replaced temperature sensor but still have the same error"
You said in your first post that it was giving the F3 and F4 errors and you replaced the temperature sensor but it is still giving the errors.
Or did I misunderstand this.
The tech sheet shows F3 as an open sensor and F4 as a shorted sensor.
This makes no sense as they are exact opposites and that is why I believe that something on the control board must be screwed up.
You could pull the sensor and check it with a meter should be approximately 1,100 ohms.
You could also check that the ground strap (if a 3 wire hook up)
and Neutral are tight. Sometimes a bad earth ground can do weird things.
Hopefully someone else will jump in with additional thoughts/solutions to this problem.
Tim Lim
#7 Posted : Wednesday, December 16, 2009 7:34:07 AM(UTC)
Tim Lim
I'm sorry, I'm not being clear. Let me describe the original problem. The oven would turn on and heat up to the set temperature and then error F3. I replace the temperature sensor and it still does error F3 and when I cancel it and start again, that's when I get error F3 and then F4. Hope this make more since.
#8 Posted : Wednesday, December 16, 2009 4:24:30 PM(UTC)
Very weird.
All I can suggests is that you try the stuff in may last post.
Also check to see if the connector for the temperature sensor on the board is OK. Check the pins for corrosion usually a light gray or tan coating. Also check that the pins are properly soldered in. Wiggle the pin while carefully watching the solder if the pin moves in the solder it is a bad solder joint. Also cold solder joints are usually a duller silver color or have pin holes.
All this of coarse is done with the unit unplugged.
I cannot explain why you get an open sensor fault and then a shorted sensor fault. This may just be the way they monitor the sensor re: if the sensor reading drops suddenly it may trip a shorted sensor error.
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
GU2300XTVS0: Random pattern on lights & keypad sometimes no responsive [Quiet Partner III] (Dishwasher Repair)
by ocallau 3/3/2024 9:59:15 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
