PJ3
#1 Posted : Wednesday, July 25, 2007 5:45:03 AM(UTC)
PJ3
Works great until drain cycle....timer does not advance and machine is completely silent. Lid switch appears to be good when ohmed and when performing a by-pass test, washer still fails to enter drain cycle. Any suggestions? Also, when checking the lid switch.....what is a normal ohm reading? Again, washer is a kenmore/whirlpool 80 series model number 110.28812790. Thank you, pj3
Blammer
#2 Posted : Thursday, November 15, 2007 4:14:32 PM(UTC)
Blammer
I too have a Kenmore 110.28812790 and it won't drain, the dial will fill, spin to wash, but then nothing, no drain, no spin, tried it on all the different cycles and the only thing that works is the fill, and wash, but nothing else.
could this be the lid switch?
mauriceiera@yahoo.com
#3 Posted : Wednesday, November 25, 2009 6:30:46 PM(UTC)
can someone help me i have a whirpool gold and after the washing cycle is over it does not drain or spin cycle it just stops.is there a part that has to be changed and what part do i need so i could do it myself.please i need an answer a.s.a.p water is still in the tub since last night
thks
#4 Posted : Friday, December 11, 2009 1:13:05 AM(UTC)
I would temporarily bypass the lid switch with a wire and see if it works.
Washer will not drain or spin. (Washer Repair)
by albouldin 12/3/2010 9:21:23 AM(UTC)
Whirlpool washer will not drain or spin. Is it the lid switch? (Washer Repair)
by conramana 6/10/2009 7:48:12 PM(UTC)
Will not drain or spin... (Washer Repair)
by lonestarmdw 12/16/2007 5:57:38 PM(UTC)
