brunettes
#1 Posted : 17 years ago
brunettes
Hi I have a FRIGIDAIRE GLGF388ABC its about 3 years old and all of a sudden the digital oven display isn't working. What can I do? The stove top was working but now its not even lighting? I tried unpluging it and still nothing. If I order a new display will that fix the problem?
Thanks,
S
#2 Posted : 17 years ago
The first thing I would check if there is 120V at the power outlet.
If nothing works - the problem most likely is with the power source.
Here are the break down diagrams for the Frigidaire range Model GLGF388ABC
brunettes
#3 Posted : 17 years ago
brunettes
I have checked the Ac outlet and there is no problem. The whole digital display is out. After I noticed it I tried the cook top and it light, no problem. I have tried it since and it no longer lights and the pilot light is also out. I do however still have gas that will come out from the cook top. So I no its not the plu or the gas. By changing the digital display do you think it would repair the problem? I know this oven is supposed to be all "computer" digital controled.
Thanks,
S
#4 Posted : 17 years ago
The "digital display" or the EOC controls the oven only. The ignition for the top burners operates by the ignition module.
It's very unusual for both of these parts went bad at the same time. Thats why I need you to make sure there is nothing wrong with the power supply.
Remove the back cover and check the power cord connection to the range.
Check for 120V at the terminal block.
brunettes
#5 Posted : 17 years ago
brunettes
Well tryed just changing the display with no luck :( that was a $300 mistake. I couldn't order from here, no shipping to Canada. I guess a call to the repar man now. If anyone is looking for a new display let me know..
landas214
#6 Posted : 15 years ago
landas214
I have the same problem with my frigidaire gas range - burners work, display out, no oven. do you think your display will help? what part number is it?
landas214
#7 Posted : 15 years ago
landas214
do you still have a display that works that you want to sell me? landas214@gmail.com
fooks
#8 Posted : 11 years ago
fooks
Hi, I have the same problem. Did you ever figure out what part was broken?
Please let me know. fooks@jhu.edu
