The buttons on this double oven under the flexible plastic cover seem to move around and have become hard to find and push. I assume I need a new control panel assembly.
How do I remove the plastic cover to get access to the assembly?
What is the end of the model number?
Kitchenaid dual oven KEBS207DWH8. Another post with an answer to a similar problem suggests that there are screws on the under side of the panel cover that are accessed by opening the oven door.
This oven doesn't seem to have said screws.
I appreciate your help.
Thanks.
