i have my frig in my garage and it wont keep food frozen, i saw a article in a mag. that said there is a heater elemont you can get to fix this
can i get something to help my frig. keep food frozen when the frig is in an unheated garage
my frig is in my unheated garage and doesnt keep food frozen, any advice??
is there anyway to get it to keep food frozsen??
I believe this may help Part number: AP3722172
Kit is for a top mount fridge. Unit must be the type that uses an old style thermostat. Newer electronically controlled units are a no go. The reason food is thawing is that the defrost heater comes on, adds heat toi the freezer but the compressor never comes on to get rid of this heat because of the ambient temperature itself is keeping the unit cold. Basically this adds heat to the thermostat so the compressor will start. This should allow you to run the unit down to around freezing. If your exterior temperature is dropping much lower than freezing then I would not recommend it. The compressor has oil in it which thickens as the temperature drops so very low temperatures put an extra stain on the compressor motor when it tries to start. Here is some additional info Appliance Talk: Refrigerator in the Garage |
THIS FORUM IS DEAD!!!!!!! |
