2 Pages12>
CHFCOOK
#1 Posted : 18 years ago
CHFCOOK
Washer Wont Fill Wth Water, I Know Its A Fuse But I Dont Know What Kind Or Where It Goes.
#2 Posted : 18 years ago
CHFCOOK
Unplug the power cord. Remove three screws on top of the control panel and open it. In the middle you'll see the bracket with the fuse and the switches. It's a regular fuse and you can buy it in any electronic or electric parts store.
Also check the lid switch and the "check" switch. They should work as shown on the wiring diagram:
UserPostedImage
- Here are the break down diagrams for the Maytag washer Model LAT8035AAE
Good luck.
CHFCOOK
#3 Posted : 18 years ago
CHFCOOK
Ok, Thata Is Good Information. Now, How Do I Get Into The Washer To Change The Fuse Or Lid Switch
#4 Posted : 18 years ago
CHFCOOK
Unplug the power cord. Remove three screws on top of the control panel and open it. In the middle you'll see the the bracket with the fuse and the switches. It's a regular fuse and you can buy it in any electronic or electric parts store.
- - Here are the break down diagrams for the Maytag washer Model LAT8035AAE
Good luck.
gardenladymg
#5 Posted : 17 years ago
gardenladymg
Don't know how to post new message: Is there a way to get schematic for this washer too? It won't start. Lid switch power side tests good, but other side questionable. Not sure if fuse or switch or ?
THanks
#6 Posted : 17 years ago
Hi gardenladymg
It is very simple to post a new message. Just register on the forum an you can post it.
The wiring diagram for your washer suppose to be inside the control panel.
If it's not there you can view one attached to this reply.
- The part number for the new lid switch AP3159413
- Here are the break down diagrams for the Maytag washer Model LAT9360AAE
Good luck.
File Attachment(s):
lid switch.doc (61kb) downloaded 99 time(s).
skalesplitur
#7 Posted : 15 years ago
skalesplitur
Hello,
I also have this model of dryer, and the fuse keeps blowing when I open the lid.
Does this mean I need a new lid switch, or do I have a short somewhere?
#8 Posted : 15 years ago
I'm assuming "dryer" is mistyping and we are talking about washer.
Quote:
...Does this mean I need a new lid switch, or do I have a short somewhere?...
You have to test the lid switch for continuity to figure out if the problem is there or somewhere else.
Guest
#9 Posted : 2 years ago
Guest
Rank: Guest
Groups:
United States
My maytag mvwx500xw2 threw and shredded the drive belt. I was able to replace that, but now the washing machine will only run one load after recalibrating. The second load does not spin or drain properly, any suggestions?
Edited by user 2 years ago  | Reason: Typo
Guest
#10 Posted : about a year ago
Guest
Rank: Guest
Groups:
United States
Does anyone know if a pedistal for a matag series 4000 washer work on a new matag washer?
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 11 months ago
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan about a year ago
Maytag washer mav6257aww (Washer Repair)
by Guest about a year ago
Clicking / creaky sound Maytag Washer (Washer Repair)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 about a year ago
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg about a year ago
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair about a year ago
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 2 years ago
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
Maytag washer drive motor mount question (Washer Repair)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 2 years ago
Maytag washer control board burns out (Washer Repair)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 2 years ago
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
2 Pages12>
