refurbish_it
#1 Posted : Sunday, December 6, 2009 4:00:22 PM(UTC)
refurbish_it
I have purchased a new dryer heating element and have been told by the sale technician that it should have some OHM reading greater than zero? Is this a correct statement?
I used an OHM reading meter to test the original heating element and the new heating element and I received the same reading on both. I am confused.
Any guidance and/or information provided would be appreciated.
Thank you.
#2 Posted : Monday, December 7, 2009 12:47:52 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%203979705.pdf
Heater should be approximately 10 ohms.
You may be using too high an ohm scale.
Use the the most sensitive scale often 0 to 200 ohms.
