AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer is making a loud noise - sounds like it has marbles in the tumbler
Maytag Gas Dryer - Model #LDG4914AAE
The Dryer is making a loud noise when running. The noise sounds like it has marbles in the tumbler. I opened up the unit removed the belt from the pulley and turn the motor and got the same noise from the motor. So I am thinking it’s the motor.
The belt also looks like it has a lot of ware and over stretched. I think it also needs to be replaced.
Do you have instructions to replace the motor and belt? Something that will tell me - How do I replace the motor and belt? How much do I need to take the unit apart and in what order?
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
