:( :confused: My dryer is not spinning at all, however, it is getting hot inside. I looked on-line for manual and trouble-shooting but didn't have any luck. Is this the belt or motor? If so, what should I do? and where is the belt? Thank you, Marianne
This model does not have a broken belt cutoff switch so it will heat and the motor will turn. The belt sounds like it is broken AP2946843
Originally Posted by: gmbdinc This model does not have a broken belt cutoff switch so it will heat and the motor will turn. The belt sounds like it is broken AP2946843 Go to www.applianceaid.com-dryers on how to do it. Sorry I don't know how to insert links.
THIS FORUM IS DEAD!!!!!!! |
