tjet37
#1 Posted : Friday, December 4, 2009 4:47:24 PM(UTC)
tjet37
Dryer will not spin. It would run and then stop. If you would wait 1/2 to an hour it would start again. It does not run at all now. Is this a belt issue or a component? Maytag Neptune Model # MDE3000ayw
#2 Posted : Saturday, December 5, 2009 12:35:03 AM(UTC)
Motor drive replacement parts for MAYTAG MDE3000AYW Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Sounds like the original problem was the motor overheating.
It has an internal thermal protect which opens if the motor overheats, you then have to wait for the motor to cool down before it will reset.
I assuming that the unit does not make any noise when you try to start it.
For the current problem first try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it at the plug with a meter
L1 to L2 should be 240 volts
Next try rotating the drum by hand, it should turn fairly easily. This will let you know if the drum is putting too much of a load on the motor and causing it to overheat. If it is hard to turn then you will also have to find out what is causing this and repair it once you get the current problem fixed.
Unplug the unit.
Check the wires at the unit's terminal block to ensure one of them has not burned off.
You will see that there are 2 thermal fuses inline with the motor.
Check Item 10 in Section 6 with a meter should be 0 ohms.
Then check Item 11 in Section 5 also should be 0 ohms.
Odds are high that one of these is blown.
Other possible causes are the door switch, the push to start switch and the motor.
The jiggery pokery method of checking the fuses is:
Unplug the unit
Remove the wires from the fuse and short them together.
Tape them up so they cannot short to anything.
Plug the unit in and give it a try.
If it runs replace the fuse ASAP as they are critical safety devices.
If a fuse is blow be sure to check/clean your vent system.
If it is now running you have to find what was causing the original problem.
Give the unit's interior and motor a good cleaning.
Clean and check the blower wheel. Sometimes the blower wheel can strip so it turns but is slipping on the motor shaft.
Check the following for wear and bearing slop: rear rollers, front glides, idler wheel, motor bearings.
Here is a good link
http://www.applianceaid.com/dryers.html
Check out 10 then 26 then at the bottom of the page Check this out
Also a good idea to check the belt and the drum etc. seals.
Often this problem requires that the motor be replaced.
Basically you are giving the unit an overhaul.
Dryer will not spin (Dryer Repair)
by Hydrophilia 12/7/2010 5:53:05 PM(UTC)
Neptune Stacked Washer / Dryer Will not Spin (Washer Repair)
by acsicsila 10/19/2010 12:42:39 PM(UTC)
Admiral dryer will not spin (Dryer Repair)
by waltcrowley 4/7/2010 7:49:38 PM(UTC)
by mfleming67 12/5/2009 1:49:28 PM(UTC)
by tjet37 12/4/2009 4:48:21 PM(UTC)
dryer will not spin with full load (Dryer Repair)
by Bottels 8/29/2009 7:55:40 AM(UTC)
