Dryer will not spin. It would run and then stop. If you would wait 1/2 to an hour it would start again. It does not run at all now. Is this a belt issue or a component? Maytag Neptune Model # MDE3000ayw
It sounds like your dryer motor (shown below) is over heating and shutting off on the theral protector installed inside the motor itself ... It usualy comes back on after the motor cools and resets the thermal protector ... this is a sure indecation that your motor needs to be replaced MOTOR and PULLEY - Large "D" shaft. Part Number: AP4042922 Made by WHIRLPOOL ![UserPostedImage](http://www.appliancepartspros.com/img/dot_216.gif) Our Price: $109.83 Compare at: $164.63 You Save: $54.80 ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) In Stock Order now and it will ship Monday ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) Quantity
![UserPostedImage](http://www.appliancepartspros.com/img/clear.gif)
