Turnberry
#1 Posted : Friday, December 4, 2009 6:01:25 AM(UTC)
Turnberry
I took the back panel off for cleaning. I found a wire that is not connected to anything. It is a yellow wire with two red stripes. I cannot see any place to connect it to. What does it do and where does it go?
#2 Posted : Friday, December 4, 2009 6:55:33 AM(UTC)
Replacement parts for WHIRLPOOL LGN2000LW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203406668.pdf
Only place I can see a Yellow/Red is from the electronic control to the moisture sensor.
Turnberry
#3 Posted : Friday, December 4, 2009 7:06:12 AM(UTC)
Turnberry
Thank you very much.
Have a great weekend....
Whirlpool WFW9150WW00 loose wire on bottom (Washer Repair)
by tedshred 11/28/2018 3:13:36 PM(UTC)
Loose wire (Refrigerator & Freezer Repair)
by Hooked 10/23/2011 6:01:42 AM(UTC)
Loose Wires on Maytag Stakable Washer (Washer Repair)
by spearmint 8/23/2010 7:27:03 PM(UTC)
Loose wire = dead motor? What went wrong? (Washer Repair)
by funkykev 5/10/2009 2:25:36 PM(UTC)
