The light on my refrigerator is out and the fridge is not running.
I recently purchased a part for my refrigerator/freezer. Model bc20j. I have received the part which appears the correct one Part no. c8891605 motor-evaporator . What do I need to do to get the fan blades off and onto the new shaft.Is this pull off of the old motor shaft, and reinstall on the new motor by pushing onto the new shaft. I have looked at this fan blade, and it appears to be on very tight, and was not sure how it was to be removed.. I do not want to break this fan blade, as then my refrigerator top part will not cool.Hope to hear from someone soon. Thank you ... Dennis fleenerd@iowatelecom.net ..I need a response as soon a possible as the old motor is very noisy...
Originally Posted by: kathy walsh  The light on my refrigerator is out and the fridge is not running. Make sure there is 120VAC at the wall outlet and the power cord is plugged in. Gene.
Originally Posted by: dennis fleener  I recently purchased a part for my refrigerator/freezer. Model bc20j. I have received the part which appears the correct one Part no. c8891605 motor-evaporator . What do I need to do to get the fan blades off and onto the new shaft.Is this pull off of the old motor shaft, and reinstall on the new motor by pushing onto the new shaft. I have looked at this fan blade, and it appears to be on very tight, and was not sure how it was to be removed.. I do not want to break this fan blade, as then my refrigerator top part will not cool.Hope to hear from someone soon. Thank you ... Dennis fleenerd@iowatelecom.net ..I need a response as soon a possible as the old motor is very noisy... Dennis, As I can see on the picture, the blade just slides out of the shaft.  Gene. P.S. A new blade is very inexpensive and I would purchase a new one together with the motor.
