i have a gas range,when the oven is turned on it ignites, then heats to the required temperature ,then it normally cuts out .when the oven cuts back in to reheat to the required temperature i get a gurggling sound from the oven, even as the tube is lit .it sounds like when your barbecue blows out in the wind .i have installed a new igniter and have checked the brass jet for wear and dirt.the flame tube appears to be straight over the jet and all holes free of dirt. where should i turn next.
Remove the oven floor and the flame spreader.
Turn the bake "on" and watch the flame.
The approximate length of the flame of the oven burner is a 1/2" distinct inner blue flame.
If you see the distinct blue flame but lifting - close the burner air shutter (on the bottom of the burner tube) to the point where it will not cause the flame to lift or blow off the burner when cold.
i have tried closing the air shutter and it makes no difference it still gurrgles with it opened or closed. your comments are appreciated!
Remove the burner and, using a toothpick, clean the hole in the orifice.
i removed the orfice checked and cleaned the tip and i also cleaned the inner tip and used canned compressed air , it seems to have cleared the problem i will try the oven for a day or two then advise further .thanks for the help
oven now works,we have used it twice and all seems fine .thanks you were agreat help.
I'm glad you were able to fix it.
