glenny
#1 Posted : Saturday, November 28, 2009 6:23:55 AM(UTC)
glenny
thermador professional gas range pg366bs will not ignite after using self clean for 1st time. lights come on fan comes on but no heat
alexcorea
#2 Posted : Tuesday, December 1, 2009 3:46:25 PM(UTC)
alexcorea
there is a hot limit swithc upper side by the door ..you need to reset it just push the red pin in the middle..it should take care that problem
alexcorea
#3 Posted : Tuesday, December 1, 2009 3:47:38 PM(UTC)
alexcorea
reset the hot limit switch should be inside of the oven ...press the red pin ..
Guest (4)
Thermador oven problems (Oven Repair (including Ranges and Cooktops))
by seltzd 4/19/2012 6:13:43 AM(UTC)
Thermador Oven Problem (Oven Repair (including Ranges and Cooktops))
by Jim-C 9/29/2010 12:35:25 PM(UTC)
by austinmike 12/15/2008 3:06:38 PM(UTC)
Thermador oven problem (Oven Repair (including Ranges and Cooktops))
by CAA111 11/10/2008 3:55:34 PM(UTC)
