austinmike
#1 Posted : Monday, December 15, 2008 3:06:38 PM(UTC)
austinmike
I need a place to start tracking down an oven problem. The oven will not come on. The igniter glows red. The broiler will come on. I would appreciate if someone could steer me in the right direction.
Mike
kayakcrzy
#2 Posted : Tuesday, December 16, 2008 5:09:04 AM(UTC)
kayakcrzy
If the ignitor comes on, and does not turn the gas on, then you need to replace the ignitor. Tom ApplianceEducator.com
Servicer
#3 Posted : Friday, December 19, 2008 7:27:50 PM(UTC)
Servicer
To be sure, you need to check for 3.2 amps from the glowbar. If you have 3.2, but not gas it's the dual valve. If the amperage is less than 3.2 and you have around 120vac it's the igniter.
Thermador oven problems (Oven Repair (including Ranges and Cooktops))
by seltzd 4/19/2012 6:13:43 AM(UTC)
Thermador Oven Problem (Oven Repair (including Ranges and Cooktops))
by Jim-C 9/29/2010 12:35:25 PM(UTC)
thermador oven problem (Oven Repair (including Ranges and Cooktops))
by glenny 11/28/2009 6:23:55 AM(UTC)
Thermador oven problem (Oven Repair (including Ranges and Cooktops))
by CAA111 11/10/2008 3:55:34 PM(UTC)
