Hi, I hope you can help me I have a amana top load washer that leaks from bottom how do I fix it?:(
You need to take off the front panel and observe where the leak is coming from. Since the pump is in front, there is a good chance it is the pump or hoses or hose connection which is easily repairable. Loosen the screws at the bottom of the front panel and insert a screw driver or putty knife in the gap between the top and front near the edges to relese the clips that hold the front panel on. Here is the service manual which will take you through the process. http://www.servicematters.com/m...ary/docs/RS3100005R3.pdf
