C5
matty2tan
#1 Posted : Wednesday, November 25, 2009 6:34:53 PM(UTC)
matty2tan
Having water delivery problems in 20 year old diswasher-only runs for about 3 minutes befor giving me the C5-not enough water,check water supply code. Pulled it out from under the cabinet, checked the supply line-good pressure. Had some high water pressure in the main lines (125PSI) but got it under control with a new pressure regulater valve. Pressure seems fine at the dishwasher inlet now-not high but very good. What are the chances that the water inlet valve is bad, and how hard is it to replace?
Thanks for your input....
tommyboy84
#2 Posted : Thursday, November 26, 2009 1:44:19 AM(UTC)
tommyboy84
An easy way to check your water supply to your dishwasher:
After 3 mins. from start up, open the door and visually check the bottom of your dishwasher.
If you have an insufficient amount of water, you'll want to replace the solenoid valve.
If you have a sufficient amount of water, the volute (intake) portion of the pump is most likely in need of some cleaning. The disposal is incorporated into the volute, see that it is clean and in proper working order. Be sure to inspect the pump impeller for necessary cleaning and in good condition. ( no cracks,etc.)
Any restrictions in any of those parts of the pump will certainly drop your unit's internal water circulation pressure.
Remember to unplug your unit before working on it.
On a 10 yr. old + dishwasher, you may want to consider a new replacement unit before you invest any funds into your old dishwasher - that has served you well!
The new energy saver units are so much more efficient, do a much better job at cleaning, and so much quieter.
Check recall info at:
General Electric Recalls Dishwashers Due to Fire Hazard
[FONT=&quot]www.geappliancerecall.com.[/FONT]
Best to you.
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Maytag MVWC565fw1 bangs around (Washer Repair)
by polku3 8/24/2023 12:40:09 PM(UTC)
Maytag won't fill mvwc565fw1 (Washer Repair)
by TitoSant259 3/14/2023 7:46:09 AM(UTC)
Ice maker for KRSC503ESS (Refrigerator & Freezer Repair)
by LVBT 10/29/2021 6:39:11 AM(UTC)
Maytag Top-Loading Washer Transmission Issue? (MVWC565FW) (Washer Repair)
by Beerski 11/13/2020 10:59:24 AM(UTC)
whirlpool wmc50522hz feedback (Microwave Repair)
by anjali16 9/24/2019 9:16:47 PM(UTC)
Whirlpool WMC50522HZ Microwave (Microwave Repair)
by Neelu Soliwal 9/23/2019 9:49:33 PM(UTC)
AMANDA #AMC5143AAS WONT HEAT (Microwave Repair)
by kimidoll2642 6/11/2019 9:34:52 AM(UTC)
KitchenAid KERC506HWH3 no oven heat (Oven Repair (including Ranges and Cooktops))
by luckyatva 1/23/2016 2:29:45 PM(UTC)
Whirlpool GSS26C5XXY00 ice maker not filling with water (Refrigerator & Freezer Repair)
by amain 11/5/2012 12:35:22 PM(UTC)
Whirlpool GSS26C5 water dispenser (Refrigerator & Freezer Repair)
by DMGiantsfan 10/28/2012 4:51:16 PM(UTC)
Burner on KitchenAid KECC507 Electric Cooktop not heating (Oven Repair (including Ranges and Cooktops))
by clevelandmom 12/28/2011 8:23:03 PM(UTC)
Kecc563hbl0 (Oven Repair (including Ranges and Cooktops))
by LOUH 12/14/2010 1:36:05 PM(UTC)
Jenn air TC507 Trash comp. Stuck in down position (Trash Compactor Repair)
by mtautoken 2/16/2009 6:35:10 AM(UTC)
