AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore washer 80 top agitator does not move with bottom agitator
Upper agitator is fastened correctly but does not move with motion of bottom agitaor unless you place mild downward pressure
Most likely the cause of the problem are the worn agitator clutch dogs. You can find the complete instructions in the one of my previous posts: http://forum.appliancepartspros...p-agitator-slipping.htmlIn order to provide the right part numbers I need the complete model number of the washer. Gene.
Washer Repair
