Discuss
Top agitator slipping
 in
Washer Repair
Upper agitator is slipping on the "engaged" portion of agitating. The dogs and (probably) ring of teeth they
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top agitator slipping
  #1 (permalink)
Old 08-14-2007, 09:08 AM
robejahori robejahori is offline
Junior Member
robejahori is on a distinguished road
Default Top agitator slipping
Model Number: LA780XTNO   Brand: Whirlpool   Age: More than 10 years
Upper agitator is slipping on the "engaged" portion of agitating. The dogs and (probably) ring of teeth they are supposed to engage with are not meshing enough to turn the upper agitator with the lower when they are supposed to. If I order the COMPLETE AGITATOR ASSEMBLY (#AP3094459), does it all come together with grease applied etc. (?), or should I just get the AGITATOR REPAIR KIT (#AP3138838) and the grease. Just concerned 'cause the other set of teeth the dogs engage with looks to be part of the upper agitator itself, and (I think) I want to get all new "teeth".
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-14-2007, 11:02 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
robejahori
In most cases replacing the agitator clutch dogs (agitator repair kit, part number AP3138838) is good enough to fix the problem, but if you're not sure about "teeth" then it's better to replace the whole agitator (part number AP3094459 ). It comes as an assembly and you need just unscrew the old one and install the new one.
No grease needed for any part in the agitator unless you wanted stains on your garments.
- Here are the break down diagrams for the Whirlpool direct drive washer Model LA7800XTN0
Good luck.
  #3 (permalink)
Old 08-16-2007, 04:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
JasonS
You can see it on the diagram bellow
Good luck.
  #4 (permalink)
Old 09-16-2007, 10:09 AM
pcarah pcarah is offline
Junior Member
pcarah is on a distinguished road
Default
How is the shaft secured prior to removing the bolt for disassembly?Any special tools required? My unit is a LSR7233DQ0. Thanks.
  #5 (permalink)
Old 09-16-2007, 03:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The shaft is the part of the transmission (gear case). No any special tools needed.
__________________
Professional appliance repair in Los Angeles, California.
  #6 (permalink)
Old 09-17-2007, 06:59 PM
Junior Member
Default
Thanks for the help!
  #7 (permalink)
Old 09-17-2007, 07:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
My pleasure.
__________________
  #8 (permalink)
Old 04-23-2008, 10:14 AM
tim lewis tim lewis is offline
Junior Member
tim lewis is on a distinguished road
Default
how do i take the agitator off and what tools will i need
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitator won't move Lou Caples Washer Repair 1 11-20-2007 10:32 PM
Drive block keeps slipping. vanmaarth Washer Repair 3 08-15-2007 09:00 PM
Agitator Won't Turn Manually? CAN I DO IT Washer Repair 1 07-27-2007 10:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
