9 Pages«<23456>»
evo
#31 Posted : Monday, November 2, 2009 8:20:58 PM(UTC)
evo
A step by step with pictures is given on page 2. With other commenting on additions they have discovered while replacing their springs.
superbadoor
#32 Posted : Friday, November 20, 2009 5:58:04 PM(UTC)
superbadoor
I have a broken original RH spring and have purchased 2 medium weight springs for the replacement. Problem is that the LH and RH springs are wound differently (different bends). The medium weight spring is wound as a RH spring. I cannot understand how to use it as a LH spring.
marksman
#33 Posted : Monday, January 25, 2010 6:36:36 PM(UTC)
marksman
I have a GE JES738WJ microwave from walmart Walmart.com: GE 0.7 Cu. Ft. Capacity Countertop Microwave Oven, JES738WJ: Appliances
The problem is that I'm always woken up at night or in the morning by my housemate opening and closing the microwave door. The main source of noise I believe is when the door latch 'falls' into its slot when the door is closed.
Can I remove the spring entirely from the door latch? that way when the door is closed the latch isn't spring loaded so hopefully it won't make as much noise.
My other ideas was to take out the door latch entirely. In that case I would have to find another way to keep the door closed, maybe by inserting a small magnet to keep the door closed.
Any other suggestions?
Pointmanpl
#34 Posted : Friday, January 29, 2010 10:00:29 AM(UTC)
Pointmanpl
Before I saw this wonderful detailed post my son in law tried to take oven apart and removed a few torx screws which did not loosen anything we needed but when he replaced the upper left one something got loose and now the microwave oven comes on when started but does not cook anything.
Got the springs replaced now due to this great post but now no cooking.
anyone know how this can be fixed?
MACBTWO
#35 Posted : Monday, February 8, 2010 9:47:12 AM(UTC)
MACBTWO
How do you know left hand from the right hand? Is the j hook that is on the right side a right hand spring?
Mod KBMC140HSS03
SER. XP4807870
PART #(I think) AP3082257 RH
Pointmanpl
#36 Posted : Monday, February 8, 2010 12:22:07 PM(UTC)
Pointmanpl
The right hand one had a yellow mark on the spring on the end. Essentially they look identical until you hold them up together and notice the bend in the one is opposite the bend in the other.
accessrb
#37 Posted : Friday, February 19, 2010 5:55:59 PM(UTC)
accessrb
Well still waiting for the recommendation on springs from Kitchen Aid so I replaced the spring with the original number 4452396 RH SS models.
Follow the instructions with the pictures the reverse to reassemble.
great pics and appreciate,,,however, when pulling out the microwave out a little to get the lower screws out of the plastic door frame..the top vent broke..so...as i was tring to get it out it broke real bad.
What do I have to do to get the new one in?
tried prying it but didn't want to break it again
Any ideas or great pics like last time?
nikkibgood
#38 Posted: : Saturday, March 27, 2010 4:52:39 PM(UTC)
nikkibgood
Thanks for posting these excellent instructions! The visuals made a huge difference!
Davidf2010
#39 Posted : Friday, August 20, 2010 12:21:23 PM(UTC)
Davidf2010
I recently used this excellent post to fix my KA SS microwave torsion spring. Thanks Evo!
I noticed one thing not mentioned on any of the prior posts. When removing the plastic inner panel after the outer door comes off, there are only the 2 screws on the bottom holding it in place. After I repaired the spring and put the door back together, I noticed the bottom of the micro door pulled away slightly from the micro as if it wasn't anchored somewhere. I saw this during opening and closing of the door. I ended up putting a screw on each side of the plastic inner panel on a small round tab that lined up with a hole on each door hinge (where the torsion spring is anchored) on each side. This fixed the door from having that wobbly unanchored feeling. Did anyone else run into this or did I miss something in reinstalling the plastic door panel?
evo
#40 Posted : Monday, August 23, 2010 8:30:41 AM(UTC)
evo
Thanks, I have noticed the bottom of the door seeming like its hanging loose. There is no attachment by screws for the inner plastic there from the factory. Next time I have it apart I will look for the taps you added screws to. I thought I looked for someplace to add screws but didn't see anything last time. There really needs something to keep the door together there since the bottom does hang loose. If bad enough it binds when the door closes.
Guest (4)
9 Pages«<23456>»
