2 Pages<12
cmpitt
#11 Posted : Tuesday, November 10, 2009 4:28:48 PM(UTC)
cmpitt
jrz, thanks. I ordered the thermoster today. They said I can return the board. If you call, they will email you instructions on how to return. I think the main thing is the 30 day policy and new condition. I pulled it out this evening and I am returning it tomorrow. I really hope the new part does the trick. thanks for your help.
#12 Posted : Tuesday, November 10, 2009 5:21:02 PM(UTC)
cmpitt
#13 Posted : Thursday, November 12, 2009 4:24:20 PM(UTC)
cmpitt
my $5 thermoster seems to have fixed my problem. Took about 10 minutes to fix. JRZ you were right on. Thanks so much. Finally fixed. For 8 hours I have been at 10f.
cmpitt
#14 Posted : Saturday, November 14, 2009 11:43:54 AM(UTC)
cmpitt
All is working fine, had one more water backup but I know the drain was frozen from the prior sub 0 temp. I let it all thaw for about 4 hours and all is good. thanks
#15 Posted : Saturday, November 14, 2009 3:32:35 PM(UTC)
You are welcome. We are glad you were able to fix it.
JRZ
#16 Posted : Tuesday, November 17, 2009 5:51:26 PM(UTC)
JRZ
cmpitt - You are welcome ! I too replaced the 5$ thermistor - I ordered and received a pair just in case one fails again - Now I will call about returning the 200$ control board - FOR ANYONE ELSE READING THIS STRING THE PDF MANUAL GENE POSTED IS A GREAT HELP. IT ALSO EXPLAINS THE THERMISTOR FAILURE "DEFAULT MODE" - If either thermistor fails completely (it must be disconnected to fail completely) the RC or FC will default into a cyclycle mode versus a temperature sensetive mode. This may help maintain more normal temps until it is fixed.
2 Pages<12
