dmaloon
#1 Posted : Tuesday, November 17, 2009 12:34:21 PM(UTC)
dmaloon
Hi
I have a Jenn Air CVG 2420B and can replace it with a CVGX2423B. The problem is that I have had several problems with the fan switch on my current model and am worried to replace it with another stove with the same faulty part.
Is there a replacement for this part # AP367072 that would work with the Jennair CVGX2423B? What does the grommet, that is available, do, ie part #AP4292546 ?
Thanks so much
#2 Posted : Wednesday, November 18, 2009 5:15:01 AM(UTC)
Here are the parts for a GVGX2423B
Top assembly replacement parts for JENN-AIR CVGX2423B | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010492.pdf
Here are a couple tech bulletins on the fan switch
http://www.servicematters.com/m...ary/docs/TDC-0021A-B.pdf
http://www.servicematters.com/m...rary/docs/TDC-0102-B.pdf
If I cross reference to this site 74009245 comes up as
Part number: AP4097683
12002045 comes up with the above but also with another part. You would have to check with the parts people at AppliancePartsPros to clarify the difference.
As far as I can see the grommet fits into the hole for the switch so that there is some give, so the glass does not crack with expansion/contraction.
