BKC68
#1 Posted : Monday, November 16, 2009 12:44:01 PM(UTC)
BKC68
dishwasher wont drain on its own..checked for clogs but found out if you just let it run it skips the drain cylce..if you turn the knob manually with your hand through all the cycles it will drain when it hits that cycle. is the timer out?
#2 Posted : Monday, November 16, 2009 5:52:34 PM(UTC)
Sounds like the timer is the culprit.
- The timer Part number: AP3744661
BKC68
#3 Posted : Monday, November 16, 2009 7:42:12 PM(UTC)
BKC68
thought so too....cheapest i found is 114.00 ouch!
Whirlpool wont drain or spin w/buzz at timer (Washer Repair)
by ssgshooter 12/19/2009 9:21:58 AM(UTC)
