The spin cycle varies speed, but generally spins slower than normal. The clothes are wetter than usual. Also while spinning there is a clicking sound coming from the front near the pump
Thanks a lot Guys. I'll check the Coupler and for a clog. Let you know how it goes.
Okay I've checked the coupler. Seems okay and doesn't look worn. I've also checked for a blocked drain. Nothing there either. Any other suggestions? I can rotate the drum by rotating the clutch by hand clockwise. Rotating the clutch counter clockwise, the clutch will turn about a quarter turn then stop.
You may have brakes which are hanging up. Check Richappy's sticky on direct drive brakes and take out the transmission and brake tube and see if you have any problems.
Thanks again for your reply. I'll check the brakes.
Have you ever heard of the motor start switch causing the clicking problem? I've noticed the contact arm on the switch doesn't seem to slide on the contact wheel smoothly, rather it jumps and coincides with the speed of the clicking.
I haven't heard of that, and I think you will find your problem with the clutch or the brakes, and let us know how what you find out
Yep, you're right. It's the brakes dragging. The clicking sound was from the motor switch arm chattering against the wheel it rides on. The motor was jerking due to the brakes binding. Thanks again for your help. New brakes and it's working fine.
Great, glad you got it fixed, and some credit has to go to Richappy. Thanks for the update.
