seynett
#1 Posted : Friday, November 13, 2009 6:31:17 AM(UTC)
seynett
The spin cycle varies speed, but generally spins slower than normal. The clothes are wetter than usual. Also while spinning there is a clicking sound coming from the front near the pump
sidfink43
#2 Posted : Saturday, November 14, 2009 3:10:36 PM(UTC)
sidfink43
Check your coupling, sounds like it may be in the process of breaking up. On the way in check to make sure nothing is caught in the pump or drain hoses.
Here is a video which will show you how.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
seynett
#3 Posted : Saturday, November 14, 2009 5:21:52 PM(UTC)
seynett
Thanks a lot Guys. I'll check the Coupler and for a clog. Let you know how it goes.
seynett
#4 Posted : Saturday, November 14, 2009 6:15:01 PM(UTC)
seynett
Okay I've checked the coupler. Seems okay and doesn't look worn. I've also checked for a blocked drain. Nothing there either. Any other suggestions?
I can rotate the drum by rotating the clutch by hand clockwise. Rotating the clutch counter clockwise, the clutch will turn about a quarter turn then stop.
sidfink43
#5 Posted : Sunday, November 15, 2009 4:46:28 AM(UTC)
sidfink43
You may have brakes which are hanging up. Check Richappy's sticky on direct drive brakes and take out the transmission and brake tube and see if you have any problems.
seynett
#6 Posted : Sunday, November 15, 2009 1:59:58 PM(UTC)
seynett
Thanks again for your reply. I'll check the brakes.
Have you ever heard of the motor start switch causing the clicking problem? I've noticed the contact arm on the switch doesn't seem to slide on the contact wheel smoothly, rather it jumps and coincides with the speed of the clicking.
sidfink43
#7 Posted : Sunday, November 15, 2009 2:30:16 PM(UTC)
sidfink43
I haven't heard of that, and I think you will find your problem with the clutch or the brakes, and let us know how what you find out
seynett
#8 Posted : Tuesday, November 17, 2009 1:28:11 PM(UTC)
seynett
Yep, you're right. It's the brakes dragging. The clicking sound was from the motor switch arm chattering against the wheel it rides on. The motor was jerking due to the brakes binding.
Thanks again for your help. New brakes and it's working fine.
sidfink43
#9 Posted : Tuesday, November 17, 2009 1:45:06 PM(UTC)
sidfink43
Great, glad you got it fixed, and some credit has to go to Richappy. Thanks for the update.
Guest (5)
