rrodgers12@woh.rr.com
#1 Posted : Saturday, November 14, 2009 6:02:51 AM(UTC)
My door on my Whirlpool DU8OCWDB3 is leaking pretty badly mostly coming from the left side of the door. Since I am a novice any advice as to what part I should be looking at to replace. The seal in the door looks a little flat is that where I should start? Any help would be deeply appreciated
magician59
#2 Posted : Saturday, November 14, 2009 5:27:48 PM(UTC)
magician59
Yes. And make sure it is clean. Food and soap residue can cause the seal to be open at those spots. If it leaks after a good cleaning, you can replace it. Here's the part number. Part number: AP4310431
#3 Posted : Sunday, November 22, 2009 5:56:16 AM(UTC)
Yes,
The seal was the problem. I tried to get a new part however, they are out of stock. I took the old seal out and soaked it in warm water with a little dish soap. I rubbed the seal dry and replaced it. I was able to work the seal to cover the entire opening and it worked like a champ. After a couple of uses the seal shrunk again. I have to rework the seal every couple of uses until a new seal becomes available for purchase.
Thank you for your help.
