reneesue57
#1 Posted : Wednesday, February 13, 2008 3:58:03 PM(UTC)
reneesue57
I have a Kenmore side-by-side refrigerator with a broken water actuator lever. I ordered and received the replacement (part #24 from schematic) but can't seem to get the panel off to access the part. Anyone else had this problem? Go in from front?? or back??
#2 Posted : Thursday, February 14, 2008 2:18:11 PM(UTC)
The dispenser has to be taken apart from the front.
The frame is holding by the three screws (#82 on the break down diagram) on the bottom.
Do not forget to unplug the fridge first.
reneesue57
#3 Posted : Thursday, February 14, 2008 5:33:29 PM(UTC)
reneesue57
Thanks Gene...got the disassembly figured out...put the actuator in, now when I plug the front panel back in the ice dispenser runs continuously!! Any easy suggestions? or should I through the towel (or the ice bucket!!) in and call a repairman?
#4 Posted : Thursday, February 14, 2008 7:34:05 PM(UTC)
Looks like the switch inside is stuck. Possible you misalign the actuator.
Guest (5)
Replace broken water actuator (Refrigerator & Freezer Repair)
by JoeSup 12/4/2009 8:10:39 AM(UTC)
