lauraftrask
#1 Posted : Tuesday, November 10, 2009 10:28:39 AM(UTC)
lauraftrask
F1 Error Code On G E Advantium Oven. Spoke With Pros At Just Answer.com. They Led Me To Parts From You. Bought Them And It Worked For Couple Weeks. Received Another Sensor (free) And Now Getting F1 Error Code Again. Also Now Lights Wont Come On But Microwave Still Working. Please Help. I Cant Afford The Crazy Fees That Sears And Ge Want.
#2 Posted : Tuesday, November 10, 2009 12:05:34 PM(UTC)
Which parts did you replace?
The "F1" error code means the oven cavity thermistor (#1410 on the diagram) is open.
- The thermistor Part number: AP2026224
lauraftrask
#3 Posted : Tuesday, November 10, 2009 3:18:01 PM(UTC)
lauraftrask
I replaced Part #1454 a sensor that an expert from just answer said was the problem with the f1 code
#4 Posted : Tuesday, November 10, 2009 4:44:15 PM(UTC)
If it was the same "F1" error code then according to the Service manual the cavity thermistor is the culprit.
lauraftrask
#5 Posted : Tuesday, November 10, 2009 5:24:37 PM(UTC)
lauraftrask
Thank you. I am ordering part and giving it a try. :)
#6 Posted : Tuesday, November 10, 2009 5:34:50 PM(UTC)
