F1 Error Code On G E Advantium Oven. Spoke With Pros At Just Answer.com. They Led Me To Parts From You. Bought Them And It Worked For Couple Weeks. Received Another Sensor (free) And Now Getting F1 Error Code Again. Also Now Lights Wont Come On But Microwave Still Working. Please Help. I Cant Afford The Crazy Fees That Sears And Ge Want.
Which parts did you replace? The "F1" error code means the oven cavity thermistor (#1410 on the diagram) is open. - The thermistor Part number: AP2026224
Originally Posted by: Gene Which parts did you replace? The "F1" error code means the oven cavity thermistor (#1410 on the diagram) is open. - The thermistor Part number: AP2026224
I replaced Part #1454 a sensor that an expert from just answer said was the problem with the f1 code
If it was the same "F1" error code then according to the Service manual the cavity thermistor is the culprit.
Originally Posted by: Gene If it was the same "F1" error code then according to the Service manual the cavity thermistor is the culprit.
Gene. Thank you. I am ordering part and giving it a try. :)
