I have a GE wall oven model JTP20BF1BB what I'm looking for is the power cable that connects the lower heating element to the power source. Look athe the part diagram but it doesn't show that cable that connects the lower heating element.
The cable is a solid wire wraped in heat treated tape that has wire ring lugs that are screwed onto the heating element that comes thru the rear of the oven.
Need part number!!!!!
