I dropped a tray on top of the Glass Door of the Range and somehow some of the juice from the cooking spilled on the glass and it went in between the exterior and interior glass. It can't be cleaned and it looks very ugly :mad: . Can I just replace the Door. Thanks
I need the complete model number of the unit. You can find it on the frame behind the bottom drawer.
Sorry for the delay in answering back, but here is the NO. 17B6641P001.
The model number you posted is not a valid GE model number. It should start with a few letters.
Verify and repost it, please.
Hi Gene,
Sorry about that :eek: . Here it is JG13908SEK2SS. Thanks
This model number does not come up too.
I hope I am getting it this time and really sorry about that. JGB908SEK2SS I must have read the B as 13 instead. Thanks
GE does not sell the whole door and you do not need it if nothing is broken. You can clean all interior parts. Look into the break down diagram and you'll see how simple it is. Remove the door from the range and put it on a flat surface with the front of the door facing down. Remove all screws holding the inner door panel. Remove the inner door panel and it's all yours. Gene.
Thank you veryyyy much.:)
