imangobran
#1 Posted : Wednesday, February 6, 2008 8:09:36 PM(UTC)
imangobran
I dropped a tray on top of the Glass Door of the Range and somehow some of the juice from the cooking spilled on the glass and it went in between the exterior and interior glass. It can't be cleaned and it looks very ugly :mad: . Can I just replace the Door. Thanks
#2 Posted : Thursday, February 7, 2008 11:54:28 AM(UTC)
I need the complete model number of the unit. You can find it on the frame behind the bottom drawer.
imangobran
#3 Posted : Sunday, February 10, 2008 2:15:26 PM(UTC)
imangobran
Sorry for the delay in answering back, but here is the NO. 17B6641P001.
#4 Posted : Monday, February 11, 2008 10:17:56 AM(UTC)
The model number you posted is not a valid GE model number. It should start with a few letters.
Verify and repost it, please.
imangobran
#5 Posted : Monday, February 11, 2008 3:38:46 PM(UTC)
imangobran
Hi Gene,
Sorry about that :eek: . Here it is JG13908SEK2SS. Thanks
#6 Posted : Monday, February 11, 2008 3:51:07 PM(UTC)
This model number does not come up too.
imangobran
#7 Posted : Tuesday, February 12, 2008 6:21:50 AM(UTC)
imangobran
I hope I am getting it this time and really sorry about that. JGB908SEK2SS I must have read the B as 13 instead. Thanks
#8 Posted : Tuesday, February 12, 2008 9:27:55 AM(UTC)
GE does not sell the whole door and you do not need it if nothing is broken. You can clean all interior parts. Look into the break down diagram and you'll see how simple it is.
Remove the door from the range and put it on a flat surface with the front of the door facing down.
Remove all screws holding the inner door panel. Remove the inner door panel and it's all yours.
imangobran
#9 Posted : Tuesday, February 12, 2008 9:55:27 AM(UTC)
imangobran
Thank you veryyyy much.:)
Guest (5)
Range door glass/moisture barrier (Oven Repair (including Ranges and Cooktops))
by stevirey 12/7/2009 9:31:56 AM(UTC)
Gas Range Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ronkat 11/16/2007 3:08:54 PM(UTC)
