wendys
#1 Posted : Monday, February 11, 2008 1:17:41 PM(UTC)
wendys
I took the cover access assembly panel "thingy" off the back of my fridge because it was warped and bubbled. it was almost like paper. anyway, i proceeded to pull the insulation out from around the motor and fan and now I can't find a replacement assembly panel, as GE has discontinued it and I don't have any information about the insulation stuff either. I threw it all out..:confused: can anybody tell me what I should do? the fridge works fine, but was very dirty "under there", hence the clean out:(
#2 Posted : Tuesday, February 12, 2008 12:15:57 PM(UTC)
It is very important to have the cover (#616 on the unit break down diagram) in place to maintain a proper air flow inside the compressor compartment.
You can make a cover from a cardboard and just tape it to the body.
The purpose of the insulation is to decrease the noise and it's not affecting anything.
