cmpitt
#1 Posted : Monday, November 2, 2009 4:29:41 PM(UTC)
cmpitt
I get a few inches of ice built up in the bottom of the freezer after a few weeks. My freezer is reading -10f and I have it set to 5f. I did the test on the termistor and it coded that it was working. I read that I had to replace the micro computer your part number AP3177964 and my freezer still jumping from -10 to 0 depending on when I check it. It has only been a few days and no ice build up yet but I am expecting it. What temperature should this freezer be?? Any suggestions on what may be wrong. I know the defrost cycle works fine. Thanks for any help.
cmpitt
#2 Posted : Tuesday, November 3, 2009 2:44:53 PM(UTC)
cmpitt
I already bought a $215 dollar part that I just found out I can not return. Do you have any idea what is causing my freezer to be too cold and eventually ice building up????????? thanks
doityourselfer
#3 Posted : Friday, November 6, 2009 6:32:03 AM(UTC)
doityourselfer
Did you ever get a response? My Kenmore Elite is doing the same thing.
novice22
#4 Posted : Sunday, November 29, 2009 5:57:33 PM(UTC)
novice22
ice collects in the bottom of my freezer in drip pan. Water leaks out the front if I don't clear the ice. Any idea of the problem? Thanks
cmpitt
#5 Posted : Monday, November 30, 2009 2:53:24 PM(UTC)
cmpitt
I do not know what type you have but my problem was fixed with a new themoster for the freezer. It only costs like $5 or so. I would check the temperature in your freezer. My freezer was getting like -20f or so and that is what led up to the ice build up. Since I have replaced this part my freezer has been at 10f and no more ice. It works perfect.
salty1122
#6 Posted : Sunday, August 16, 2015 2:30:28 PM(UTC)
salty1122
I have a Kenmore elite model 795.7105 I'm getting water on the floor and found ice build up on the bottom of the freezer. I cleaned the ice out but in 4-5 days it has happened again
