THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Thanks. I got it apart and cleared some debree from around the chopper assembly. But when I got it back together its still making the same loud noises. I didnt remove the check valve though while I was in there.
You hay have to pull the motor to check that the bearings/seals/chopper are OK. |
