tommoran
#1 Posted : Saturday, October 31, 2009 10:22:23 AM(UTC)
tommoran
Can someone tell me how to remove this WASH Arm assembly ?
I need to check the Chopper due to excesive noise. Theres a small plastic cap on the top but I dont want to break the thing by trying to loosen it.
Here is a link to the arm asssembly Lower washarm parts replacement parts for WHIRLPOOL GU2400XTPQ7 | AppliancePartsPros.com
Tom
#2 Posted : Sunday, November 1, 2009 2:16:55 AM(UTC)
tommoran
#3 Posted : Sunday, November 1, 2009 11:42:29 AM(UTC)
tommoran
Originally Posted by: denman Go to Quoted Post
Thanks. I got it apart and cleared some debree from around the chopper assembly. But when I got it back together its still making the same loud noises. I didnt remove the check valve though while I was in there.
#4 Posted : Monday, November 2, 2009 1:26:44 AM(UTC)
You hay have to pull the motor to check that the bearings/seals/chopper are OK.
