gimme789
#1 Posted : Monday, March 23, 2009 4:18:57 PM(UTC)
gimme789
The Rotary Knob on my Thermador Electric Range has become unuseable .. "stripped" is the best word I can describe it as.
The knob is used to set "bake", broil", "clean", etc...... by rotating through different click positions, and then then with a lighter touch (no clicking) the temperature can be set by applying pressure to the knob (left or right) without clicking.
I believe that I need item #5 here (selector switch w\BUSS) :
Replacement parts for THERMADOR CT130 | AppliancePartsPros.com
Can anyone help ? Not sure if this will be th only part I need .....
How difficult will it be to get at the switch ?
Any help / ideas welcomed.
Thanks in advance
Tom
Phumigator
#2 Posted : Sunday, November 1, 2009 11:36:52 AM(UTC)
Phumigator
I know this is an old post and I hope you found your rotary switch. I just moved into a house that has the same oven and can't figure the oven out.
Do you happen to have the owner's manual? I can't seem to find it online. I can't even change the clock and can't figure out how to use the self clean (I get and E3 message).
Would appreciate if you could help.
Phu-My
rattus
#3 Posted : Tuesday, July 13, 2010 8:17:25 AM(UTC)
rattus
Hi - I have the same problem with the same rotary switches on my Thermador CT227. Symptom is that it's difficult (many tries are needed) to set a temperature, start a clean cycle, etc. Upper oven simply can't be set to clean any more.
I have a replacement switch; seems to be common across the Thermador range, have the "control compartment" lid pulled off, but can't figure out how to either:
1) remove the existing switch, and/or
2) remove the front control panel to access any hidden screws, clips, etc.
Anyone have an idea?
Thanks,
Mike
Guest (5)
