ncord51
#1 Posted : Sunday, November 1, 2009 8:06:44 AM(UTC)
ncord51
The unit is a BUCK Stove propane vent free...it works fine but recently, the pilot light grew from about a quarter of an inch to around a full inch or more...Looking at the unit, it isn't obvious how or what to replace...
Any info would help...
Thank you
1
Nick
SublimeMasterJW
#2 Posted : Sunday, November 15, 2009 11:00:29 AM(UTC)
SublimeMasterJW
UserPostedImage
ODS (oxygen depletion system) gas safety heaters/fireplaces. Notice the hole to clean arrows. You can use a straw to blow out the dust or shop air also. When the dust is removed the heater will work properly
ncord51
#3 Posted : Monday, November 16, 2009 5:09:43 AM(UTC)
ncord51
Thank you for the reply!! It isn't the hole though...the hole is completely clear...I blew it out thoroughly. The design I have has a thin metal piece covering one side of the hole. If I lift it off, the flame intensifies...
SublimeMasterJW
#4 Posted : Monday, November 16, 2009 6:25:19 AM(UTC)
SublimeMasterJW
get some rust buster and flush the pilot
