I just installed the High Torque Tranny. The support springs do not support equally. The springs attached using the Hooks are loose. Is the new tranny a different height? What can I do to correct this prob.
Check the proper installation of the transmission supports. Check the Service manual (pages 24 & 25). Gene.
Originally Posted by: Gene  Check the proper installation of the transmission supports. Check the Service manual (pages 24 & 25). Gene. Thanks Gene! Especially for the Service Manual! I have the machine working properly, but the springs are too loose (only the three attached to the upper support). I believe that the top support "floats" and can be adjusted upwards without having to disassemble can you verify?:rolleyes:
