I found my washing machine stuck in the spin cycle. I can only advance the cycle manually. I'm assuming that the timer is bad. How do I test the timer?
Did it get cold water for the rinse cycle? Did it always stop at the same point? If the both answers are "yes" - the timer has to be replaced. - The part number for the timer is AP2911959 Here are the break down diagrams for the Roper washer Model AL6245VW0Gene.
Yes to both. Thanks for your help.
Keep me updated, please.
