i bought the replacement oven door trim kit item#ap3176314 it has changed from the old part which was screw in the new one is pop in and came with 2 bottom brackets instead of the original 1 i need a diagram on the new config. thank you
Rank: Administration
This is right from the kit description on our site: NOTE: This part has been redesigned by the manufacturer. The lower screws are no longer used and the side trim now locks into the lower trim with the dimples on the lower end of the side trim.
Originally Posted by: Admin / APP Team  This is right from the kit description on our site: NOTE: This part has been redesigned by the manufacturer. The lower screws are no longer used and the side trim now locks into the lower trim with the dimples on the lower end of the side trim. is there a diagram for install of the new parts? thank you
Ftalk,
Whirlpool does not provide installation instructions or diagrams for this redesigned kit, but it sounds like all you have to do is lock the side pieces into the lower piece. Hope this helps.
