rednran
#1 Posted : Friday, February 8, 2008 4:08:53 AM(UTC)
rednran
I need to replace the clutch and I would love a step by step guide (with pictures if possible--they help alot).
Thanks to anyone who can help.
bentwrench1999
#2 Posted : Friday, February 8, 2008 12:25:27 PM(UTC)
bentwrench1999
This job is actually easy for most do-it-yoursefers. Follow the link here which will help with MOST of the disassembly. You can probabley figure the rest out if you navigate the pages properly. Good Luck..wrench
RepairAve.com - Free appliance repair help and troubleshooting
rednran
#3 Posted : Friday, February 8, 2008 5:09:38 PM(UTC)
rednran
I see everything BUT clutch replacement there. I already have the outside taken off. Any help?
rednran
#4 Posted : Tuesday, February 12, 2008 4:29:38 AM(UTC)
rednran
Ok I got the clutch off----in doing so I found that two of the three bolts that hold up the transmission were snapped off. Before I replace the clutch could you tell me if those missing bolts could keep the machine from spinning right? Thanks.:confused:
bentwrench1999
#5 Posted : Tuesday, February 12, 2008 9:21:37 AM(UTC)
bentwrench1999
Hey Red, I've seen this before. Your washer will not spin with these bolts broken. You should be able to remove the broken bolts O.K. Maybe use an easy out. Replace the bolts, tighten each one a bit at a time, evenly until they are flush with the case. Tighten them up. It does not take a lot of torque. I would say 25-30 lbs. of torque. I would replace the coupler while you are here.Let me know if I can assist again...wrench:)
rednran
#6 Posted : Thursday, February 14, 2008 5:27:40 AM(UTC)
rednran
Thanks Bent thats what we were thinking. Sure enough we replaced the bolts and didn't replace the clutch and it works like new. Taking the clutch back for a refund---good idea not to open the package until you're sure.:D
