While baking there was a loud pop with error code F1. I unplugged stove and let it sit for an hour. The error code cleared, all numbers work on the touch pad but neither heating element works. The top burners work fine. What could be the problem?
Originally Posted by: Frigidaredout  While baking there was a loud pop with error code F1. I unplugged stove and let it sit for an hour. The error code cleared, all numbers work on the touch pad but neither heating element works. The top burners work fine. What could be the problem? F1, is a clock control failure. Replace the clock control, and that will do it. Tom ApplianceEducator.com - Parts
