AllyCleveland
#1 Posted : 15 years ago
AllyCleveland
Our Kitchen Aid KUDP02SRSS2 dishwasher apparently stopped mid-cycle the last time we used it and now does not appear to have any power, as none of the lights on the touch pad nor control panel will turn on. I have verified that the outlet it is plugged into is working correctly and have tried resetting the circuit breaker. I also verified that it is latching correctly. Do you have any suggestions? I was looking at the the diagrams for it, but didn't see any area where a fuse could be replaced. Thanks in advance!
#2 Posted : 15 years ago
Replacement parts for WHIRLPOOL KUDP02SRSS2 | AppliancePartsPros.com
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%208572216.pdf
Take a look at Item 6 in Section 1 on the control board.
Check that the hard wired or line cord murret (wire nut) connections are OK.
Only proper way to check switches etc. is with a meter.
Try to remember when exactly the unit went down as to what on the unit may have been turning on at that time so you can check it before replacing the fuse.
AllyCleveland
#3 Posted : 15 years ago
AllyCleveland
We just replaced the fuse with the new one we ordered from app.com and now the dishwasher is working again - it seems like it picked up right where the program must have stopped. Thanks again for your help!
